Will it work?
Zaeems_
I know that both my CPUs are terrible, I haven't bought any parts for years, and back when I use to buy them - I didn't have much of a budget. :whiste:
I currently have a PC with an AMD E1-1500 CPU, and. I have a spare Intel Celeron e3300. The PC I have is good overall, since I mainly use it for gaming.
I want to know if I can swap the E1-1500 with the e3300.
Specs -
Case : Thermaltake Overseer rx-i snow Edition
CPU : AMD E1-1500
GPU : AMD Radeon HD 7750
RAM : 6GB
HDD : 1TB
SSD : 120GB x 2
DirectX : 11
Puppies04
5,909
17
No. No AMD and Inter CPU's are interchanagble. They have different sockets.
Puppies04
5,909
17
On a side note, what are you trying to do with the PC. Would be a decent budget gaming rig with a cheap mobo and CPU upgrade.
Edit. I see you already said it is mainly for gaming. My point stands.
Ramses
2,871
4
There was progression prior unless I'm misremembering the upgrade paths I had back then. I'd trade some progress for compatibility at this point.
Insert_Nickname
4,971
1,696
Only if you hate progression.
Seriously? I don't think there is that much, technically, that would prevent this. Almost all external CPU communication is handled by PCIe, and DDR3-layout should be almost the same, as its a standard interface. There might be a few issues with power-delivery, but nothing insurmountable with a little standardisation. LGA-1150 is after all almost identical to LGA-1155 which is again the same as LGA-1156.
