Will it work.... Will it be good
X2sandman
86
hey everyone, i am new to this messageboard. I am just gonna post the parts which i thought would make a good comp for myslef. I just wanted to check to make sure the parts were compadible and were a good choice for the money. Here is a list, any comments and suggestions will be great -Andrew
MSI K7T TURBO2 KT133A 266MHz FSB SOCKET A- RETAIL = $85 @ www.newegg.com
Gainward/Cardexpert GeForce 2 TITANIUM Ti / 500 XP, RETAIL = $139 @ www.newegg.com
MAXTOR 6L040J2 DIAMONDMAX PLUS D740X 40GB HDD 7200 rpm - OEM = $89 @ www.newegg.com
512MB SDRAM, PC133, 168-pin DIMM = $62 (+16% off anandtech.com users) www.crucial.com
Mircosoft Intelli Mouse Explorer =19.99 @ compusa (saw it in a add)
AOPEN CD-956 56x Black CDROM ? Retail = $30 @ www.newegg.com
AMD 1600+/266 FSB Athlon XP PROCESSOR CPU ? RETAIL = $139 @ www.newegg.com
Antec 1030B = $89 @ www.Directron.com
Dell quiet key 104 key = $10 @ www.directron.com
murphy55d
11,542
Kt133?
Go with the EPoX 8K7A(AMD 761) or 8KHA(KT266a) , the 7a is $92, and the HA is 105, which isnt too much more than what the MSI is. I have that board(7A) and I think it is very stable, has easy OC features, overall a very nice mobo. These are both DDR boards, so that will improve your performance as well. Just gotta switch out the SDRAM for some DDR.
btw welcome to the board. :)
ojai00
3,291
murphy55d make a good point of upgrading to a motherboard with DDR RAM. There is no point in getting an AthlonXP processor if your RAM is slow. AthlonXP works best with DDR RAM. IMO (in my opinion), I think that you should get a DVD-ROM instead of the CD-ROM. Hope this helps.
Guilty
427
The GeForce2 TI is a big mistake in my opinion. The GeForce3 TI 200 is only $40 more and has vastly more staying power.
As mentioned theres no reason not to go DDR and the Epox 8KHA+ is the favorite around here.
Everything else seems fine.
X2sandman
86
Thanks a lot, i will switch the mobo, and get DRR same insted of the SDRAM. I am not sure about the videocard though, i am still trying to decide on that -Andrew
X2sandman
86
EPoX 8K7A(AMD 761) = $105 @ www.newegg.com
MAXTOR 6L040J2 DIAMONDMAX PLUS D740X 40GB HDD - OEM = $89 @ www.newegg.com
DDR PC2100 ? CL=2.5 ? Unbuffered ? Non-parity ? 2.5V ? 32Meg x 64 256 MB = $53.03
AOPEN CD-956 56xB CDROM ? Retail = $30 @ www.newegg.com
Hows this look?
Insane3D
19,446
I would switch the mobo to the Epox 8KHA+...make sure it's the "+" model. Also, I would suggest the GF3 Ti 200 if you can afford it...not too much more and a much nicer card. Everything else looks great. :)
thedarkwolf
9,030
123
"Mircosoft Intelli Mouse Explorer =19.99 @ compusa"
Since your ordering just about everything else at newegg check out their mouse section. They have a corded logitech optical mouse for $12 OEM and they also have the Microsoft PS2 Intelli Mouse - OEM for $11. Not only are they cheaper but it would be more conveniant and save on shipping charges.
X2sandman
86
Thanks, as much as i would like the gf3 ti200, i am short on money as it is so i will have to get money off my dad or somthing. I think i will check out the mouses at newegg. -Andrew
FlippyBoy
886
everything looks real good, except for the suggestions above. i would seriously consider a motherboard with the kt266a chipset (8kha+) and for 40 bucks more, a gf3 ti200. there's a huge difference, and you will be happier in the long run.
ChrisADuffy
1,324
Get the G3 Ti 200 and you won't be remorseful later on, trust me. Gainward card at newegg is $179 I believe.
