VirtualLarry
See this post by Virge:
http://forums.anandtech.com/showpost.php?p=32993694&postcount=37
Speaking about the Pentium M:
Will Intel do the same with IB, or perhaps Haswell? Slow down the critical paths intentionally, so that they won't run above a certain Mhz wall, up to a limit on certain SKUs? All in the name of greater power efficiency? (Which Windows 8 is focusing on too.)
Is this not only going to be the end of distributed computing, but also overclocking?
http://forums.anandtech.com/showthread.php?t=2225768
The design team actually went in and slowed down paths that were running above Banias' target clock frequencies, because if a path is able to run faster than it should, it means that you're wasting power. The benefit of this is an even more power efficient microprocessor, but the downside is a microprocessor that has a clear clock frequency wall.
