i am getting this intel 802.11b mini-pci card from a centrino laptop and i am wondering if this be compatible with thinkpad t20 pentium 3 laptops ? thanks guys
THe Intel 11b card should work for the IBM T20. The problem is that there is no antenna connection, so you will be forced to use the onboard antenna built on the card. Its not considerably strong, but it will work.
ANother problem you might have is the mPCI lock inherent in most IBM laptops. Prevents you from using other mPCI cards not authorized by iBM.
