Will I notice a HUGE difference upgrading to audigy 2?
psy44
Banned
May 20, 2002
513
If I upgrade my onboard sound from my MSI 648 Max mobo, will I hear a huge difference with an Audigy 2? I have z-640's connected via MSI's S-bracket.
xXgambitXx
691
you probably WILL notice a differenc but it won't be anything major unless you're using some wierd speaker setup.
personally, i think it would be worth it to upgrade from onboard to either an audigy or Turtle Beach Santa Cruz.....but not to an Audigy2.
what's this S-bracket deal ?
GnomeCop
3,863
upgrading from onboard sound to an audigy 2 should make a difference, less overhead, probably better sound.
hey an OEM one may be a good deal.... or if you could find some rebate deal like the one newegg had a little while ago, that would definitely be worth it.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
122
The "S" Bracket is just part of the MSI onboard sound setup. It takes up a PSI slot. They also have a "D" bracket for USB ports.
Montano
14,461
Sound card and speakers go hand-in-hand. Audigy 2 is pointless with insufficient speakers.
