Originally posted by: Camofrog
what kind of mobo did they give ya in that Dell ??
if it is a Dual channel motherboard then i would reccomend get a pair of RAM or just another stick of identical 256mb
I found if you running WinXP or Win2K it likes 1024mb of RAM much better expecially if you do alot of multi-tasking, and gaming, otherwise you force windows to use your swap file on HD, and there is no way your HD is faster than your RAM.
Originally posted by: beatle
Between 512 and 1024, maybe. Between 768 and 1024, almost assuredly no.
Yup. And I still say that anyone who says they can 'feel' the difference between 512 and 1024 is just trying to make themselves feel better about spending the $$![]()
Originally posted by: TazExprez
I guess I'll buy 1 512MB SODIMM right now, and if I get a game that requires more, then I'll upgrade from 768MB RAM to 1GB RAM. Also, I may just wait and get the other 512MB SODIMM later.
SODIMM? Is this a laptop? If that's the case you might need a better video card, processor, etc. instead!
EDIT: Now I see that this is a Dimension 8600 Desktop. You will need DDR memory instead. Better know your parts before you start buying stuff!
I agree. I had 1GB RAM in one of my PC's and then I removed 512MB RAM from it in order to build another one. I didn't notice much difference, if any. But like it has been stated, it's nice to have 1GB, specially for future requirements.
Then you most assuredly have not played the hog known as DesertCombat!
