Will I be able to run Crysis in 64 bit with xp 32 bit OS?
MarcVenice
Moderator Emeritus <br>
Apr 2, 2007
5,664
Why does it even matter ? Afaik games running in 64 bit aren't any faster then games running in 32-bit. And of course not, how is a game going to run in something the OS doesn't support ? Running a 32bit app in a 64bit OS is possible, because it's a downgrade, but the other way around, wouldn't even make sense...
Cabages
2,918
Originally posted by: badnewcastle
Crysis, is supposed to run better in 64 bit then in 32 bit.
It is.
But 32 bit /= 64 bit so you will only be able to run 32 bit.
Golgatha
12,400
1,076
32bit OS = 32bit games
Looks like I might have a 3rd game to install under Vista 64 if all the talk about increased performance is true.
ZappDogg
761
Early anecdotal stories are starting to come out that the x64 version is about 10% faster.
ZappDogg
761
I'd also like to point out that x64 vista, in my experience, is superior to 32 bit. don't see any reason why you wouldn't run x64.
MarcVenice
Apr 2, 2007
5,664
Interesting ... I´m running both XP home, and Vista 64x ( ultimate, so if I wanted I could install 32x anytime I wanted ) so I guess I can check it out myself when I get Crysis. I wonder if it´s GPU or CPU related though.
mode101wpb
445
I was going to switch to x64 XP for Far Cry, but after reading and seeing the driver issues I passed. I'm sure the problem with Vista x64 is no better ie, no drivers for printers, digital cameras and etc and limited software supporting x64. With minimal performance gain, I would question if it's really worth it?
ZappDogg
761
*sigh*
If there were no drivers for x64 Vista, why would anyone run it? You're so off base it's not even laughable. PLEASE do some research before making blanket assumptions.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
The general consensus is XP 64 is garbage compared to Vista 64. I have been running Vista 64 for several months now and really only had one issue (Linksys router problem) that I was able to resolve after a little bit of research and help from ATers.
So in general I think most people agree: if you are going to go to a 64 Bit OS, then go to Vista, if you are going to go to Vista for any reason, only go to Vista 64.
Cheers,
KT
mode101wpb
445
Originally posted by: ZappDogg
*sigh*
Why did anyone run XP x64? To be different? Stable it is but with limited driver support.
Let me rephrase, I shouldn't say no drivers just limited compared to x86. Also a lot of freeware that people use, does not support it yet. IF Vista supports everything across the board then it must be a panacea afterall.
I DID my research on XP Pro x64, I passed for now. I'll pass on Vista till SP 1.
ZappDogg
761
Have fun with that. I'll be enjoying my system that is more stable than Vista x86, all the while reaping the benefits of 4 gigs of RAM. Good thing you did your research, though!
mode101wpb
445
Cheers,
KT
I investigated XP Pro x64 for CAD SolidWorks, but it wasn't a big enough gain to switch. Glad I didn't.
I'll go Vista x64 once SolidWorks supports it, as of 2008 release they don't.
DannyLove
12,876
4
that is exactly what's holding me back from upgrading to Vista.....
acole1
1,543
Just FYI for the mis/uninformed out there:
I remember reading (although I can't find the article right now) that Vista x86 drivers do not get certified until there is an x64 version available that passed MS's test. What that means, is that for every x86 certified driver, there is an x64 driver as well.
My friend just updated from Vista x86 to x64 and he has had absolutely no driver problems.
So, while I pity you for your lack of education on the matter, please don't bash until you are informed about Vista x64.
Like ZappDogg said a few posts up:
"If there were no drivers for x64 Vista, why would anyone run it? You're so off base it's not even laughable. PLEASE do some research before making blanket assumptions. "
If you're not sure about a certain device, look it up and see if there is a driver before assuming there isn't one. Vista x64 is a very different animal than XP x64. They are not even comparable.
mode101wpb
445
I remember reading (althought I can't find the artical right now) that Vista x86 drivers do not get certified until there is an x64 version available that passed MS's test. What that means, is that for every x86 certified driver, there is an x64 driver as well.
Save the rhetoric, I pity you for not searching other forums for people who have issues. Vista x64 cannot run every program and/or has the same driver support as XP x86. Just Google it and you will see.
If you have all brand new gear and software that is working then great, but I don't see it across the board for older hardware and/or software. Legacy use is a big issue.
Vista x64 requires digitally signed drivers, you cannot bypass it like in XP.
I'm not bashing Vista, let's just not sugar coat it and say it's fool proof, it's not there yet compared to x86 for the average user.
MarcVenice
Apr 2, 2007
5,664
You can bypass it lol, you simply hit f8 on bootup and disable the driver signing thingy. That's how I got the few apps, of which there were very few indeed, that initially didn't run in Vista 64x to run anyways.
