Will Home Depot cut plywood to size?
jtvang125
5,399
51
I have a circular saw but good luck cutting anything accurate. If they do, do they charge a fee or free with purchase of wood?
jmagg
2,217
458
Around here, they give one cut free and a buck a cut after.
PottedMeat
12,363
475
with a circular saw, use a guide. like a few feet of angle iron or aluminum clamped to your workpiece.
as long as you're buying the whole thing i think they'll cut anything, probably +/- 1/2" or more and i wouldn't bet it on being square.
Reactions: paperfist
Nashemon
889
86
It's been free every time I've ever had them do it. That said, their measurements have never been perfect, but I believe that is advertised. They also say they won't do any rip cuts less than 12 inches. I just have them cut it wider than I need it so I can fit it in my car then cut it at home.
I used to work there back in the day and never charged for cutting.
Exterous
20,569
3,762
I was just looking at that too. That and used table saws on craigslist. How do you cut anything wider than 24"?
If you can cut in from the otherside you can generally make it work. So if you need a 36" wide length of plywood, cut 12" off the otherside (- blade width)
I'd love a table saw but I dont really need it enough to justify the cost and space
Paperdoc
2,491
370
A lot of stores will do a few cuts for free, but they always warn you they are doing "rough cuts", NOT super-accurate. Typically they use a large saw frame system that is not really as rigid as a big table saw. They do their best to measure and get it right, but accuracy of +/- 1/8" may be all you can expect. Do not expect cabinet-making accuracy or straightness. And for speed, they often are using a rip saw or combination blade, so the cut is not a clean as a fine-toothed blade for cabinet work.
13,756
They will but don't think they'll do precision cuts, like you tell them roughly how big you want but they won't cut to the exact mm but get it in the ball park. They usually have one of those machines that can cut vertically so it can do fairly clean straight cuts I think.
As for cutting with a circular saw at home, buy a straight edge and clamps. You clamp it on then slide the saw against it while cutting. What I did is I cut a piece of wood to match the distance between the saw edge and the blade, so when I place the straight edge I put that block where my line is so the straight edge is not right at the line, but far enough that when the saw is against it, the blade is at the line.
Zeze
11,395
1,189
Free cut but not very precise. Due to the thickness of the blade itself and how the clueless rep operates it inconsistently by each cut, it's not reliable for 'finer' projects.
