What makes a 7200RPM SCSI drive so much faster than a 7200RPM IDE drive??
the manufacturers actually strive to reduce access times in SCSI 7200RPM drives, that's the difference.
how will S-ATA help out even though drives today can't touch that limit? when using multiple drives at the same time, the maximum throughput of the S-ATA controller (which is 150 megs/second I think) will potentially be easier to hit, becuase drives aren't just taking turns accessing a channel, they send and recieve at will (until the controller hits it's throughput limit).
Serial ATA helps out for the people who use 2+ IDE drives in their computer, without buying an extra controller. For example today, if you have 2 HD's, and 2 optical drives, the best IDE configuration would be to use the onboard IDE controller and a second controller, so that each drive has it's own channel (less sharing is good).
ok, so you might not need as many controllers. what else? well again you have the thin cables, if cooling your case is any concern, that's a plus.
those are the only REAL advantages that Serial ATA has over todays ATA standards.
