Will gasoline work in a diesel motor?
StageLeft
70,150
I am guessing diesel doesn't work in gasoline partly because it can't handle the compression, but what about the other way around...? Obviously it wouldn't work very well, but will it work at all?
Viper GTS
38,107
433
Nope.
A while back there was a thread where some dumbsh!t at a dealer filled a brand new VW TDI with gas.
Oops.
Viper GTS
ISAslot
2,888
107
I thought diesels had compression ratios like 20:1 and gasoline one about 8:1, so wouldn't the diesel be more resistant to compression?
Mookow
10,162
My aunt has put gas in my uncle's (early 90s) Jetta 3 times. After the third time of flushing the fuel system, she is no longer allowed to drive the Jetta.
it wont work.
A gas engine needs a spark to ignite.. a diesel engine uses compression and heat to ignite.
Viper GTS
38,107
433
THREE times?
Good God, is the woman retarded?
Viper GTS
iamwiz82
30,772
13
THREE times?
Viper GTS
i blieve that goes without saying ;)
DivideBYZero
24,117
Gas is highly corrosive and may damage fuel delivery parts more readily in a diesel engine. Mitsubishi had this issue in GAS engines when developing Gasoline Direct Injection(GDI), mostly due to the high preassure.
Also, as Gas ingnites more readily than diesel. Preignition would be a major issue if Gas was in a Diesel engine (if it went at all). With Diesel, Glowplugs get the heat up initially and then the compression/heat in the cylinders keeps the process going (thats why you wait for that dash ligh to go out before starting diesels, this is glowplug pre-heat).
Diesel in a gas engine won't go as Diesel motors work with glowplugs and high compression. The compression in a Gas engine is too low, the diesel fuel is more waxy/oily and will foul the fine injector nozzels or carb needles.
ISAslot
2,888
107
Originally posted by: The_good_guy
it wont work.
Not totally true.
My car has a 10.5:1 CR and on 89 pump gas if I turn my car off it will keep running for a bit.
DivideBYZero
24,117
it wont work.
Not totally true.
Yes, and this is called.......Dieseling. You have too much heat and bad fuel delivery.
Stark
7,735
Nope.
Oops.
Viper GTS
that was my thread and my dumbsh!t dealer. I ended up telling that dealership to screw off (lying pack of jackals) and got the same car from another dealer in LA. Great car, BTW.
So no, it will not work. It's not supposed to harm the engine, but the engine won't run. If anyone watches "the amazing race 2" (around the world race) on cbs, a bunch of dumbass racers filled up their diesel suvs with gas and ended up stranded somewhere in portugal.
teckmaster
1,256
a diesel will run on gas if you put some oil in there also. I don't remember what kind of oil but I know it works cause the Diesel Mechanics teacher at the school where I work was talking about it one day.
guyver01
22,135
61
did you make that mistake Maffy Shmabbles???
Desslok
3,780
11
Originally posted by: The_good_guy it wont work. A gas engine needs a spark to ignite.. a diesel engine uses compression and heat to ignite.
Not totally true. My car has a 10.5:1 CR and on 89 pump gas if I turn my car off it will keep running for a bit.
And your engine is not long for this world if you don't solve one of the two problems.
CraigRT
31,440
THREE times?
Viper GTS
I'll say!! :Q
DivideBYZero
24,117
It's more like:
A Diesel engine will run on oil if you put 5% gas in it.
Now for the bit that will :Q you:
A Diesel engine will run on fryer fat if you put 5% gas/alcohol in it.
A Diesel engine will run on Rapeseed oil if you put 5% gas/alcohol in it.
A Diesel engine will run on xxx oil type if you put 5% gas/alcohol in it.
Ad infinitum
deerslayer
10,153
It's more like:
Ad infinitum
Would it be cheaper to run a diesel engine on fryer fat? :D
Jeraden
Anyone who saw the last episode of Amazing Race 3 would know the answer to this. The teams were traveling through Portugal I think it was and using diesel vehicles. Half the teams filled up with normal gasoline instead of diesel - all of them broke down, was kind of entertaining to watch.
Kojak
282
I thought they would have noticed they were driving a diesel by the sound of the engine.
Beau
17,730
www.beauscott.com
It's more like:
Ad infinitum
Had a friend drive from utah to costa rica on fryer fat in a deisel jetta last year. spent maybe $50 in gas the entire way.
worth
2,369
Most modern diesel engines don't use glowplugs (for example the VW TDI).
StageLeft
70,150
I think it's quite illegal too :)
N8Magic
11,624
Incorrect. :)
