Will Freesync work through HDMI switch?
DJ-phYre
1,064
I am down to a single area where my PC and game consoles are accessed. I would prefer to splurge on a decent sized monitor and have a single screen that can be used for all. My main limitation is obviously going to be inputs.
I tried searching around, but I could not find a clear definitive answer on whether Freesync would still be usable with an HDMI switch. From what I gathered, it sounds like it would with a quality switch that supports HDCP. Is that correct? Also, I am aware that the cables matter as well. I would be purchasing the switch and all the cables needed to connect everything at the same time.
Headfoot
4,444
641
I would doubt it. Hardly any monitors support FreeSync over HDMI in the first place, most of them are only over DisplayPort
DJ-phYre
1,064
Are you saying it will not work b/c there are very few monitors that support Freesync over HDMI?
The monitor is a Dell SE2717H which does support Freesync over HDMI.
richaron
1,357
329
^ I doubt this is relevant.
I'm not sure how these switches work... If the signal isn't "processed" whilst going through the switch then whatever extra "stuff" which makes Freesync work will be passed along like usual. I'd assume this is the norm.
Headfoot
4,444
641
It absolutely is relevant. If hardly any controllers in displays support the spec, I find it extremely unlinkely that less expensive (i.e. low margin) HDMI splitters/switches/repeaters support it.
I'd proceed with the assumption unless the switch calls out Freesync over HDMI compatibility, that it wont work. Maybe you'll get pleasantly surprised, but I doubt it.
richaron
1,357
329
I said what I did because I suspect the switches just use a bunch of transistors to enable/disable different sources (if not purely mechanical), and once these are connected the switch itself is essentially invisible.
The only situation you would be correct is if there is a microcontroller inside the switches which processes the signals and would somehow be thrown off by an out of spec signal. But I don't see why they'd bother with a mic' doing that in a simple switch.
Headfoot
4,444
641
I dont think you can build a straight switch for HDMI if you want to be HDCP compatible. I believe that was specifically prevented by HDCP because thats how you would build a recording device man in the middle sort of thing. I'm pretty sure you have to do some processing at least on the HDCP side
richaron
1,357
329
I'd assume there is only HDCP issues if the data is processed in some manner, similar to what I mentioned above.*
As opposed to a simple physical pass-through which should be functionally identical to a simple cable.
Edit: *with regards to your example, sending the signal to multiple processors would be a different case than a switch which is for all intents and purposes invisible and acts like a single cable.
DJ-phYre
1,064
This is what I am assuming too. There are HDMI switches that are specifically labeled HDCP passthrough.
DJ-phYre
1,064
Freesync over HDMI needs an update from AMD's side as well as sufficient hardware from the monitors.
https://www.amd.com/Documents/freesync-hdmi.pdf
Most monitors in 2016 and above should *support* freesync over HDMI once the update comes through. I'm not sure that feature is enabled yet..... or even available.
Regards,
Vish
It is working... I have the monitor. The only question I have is if a passthrough switch allow the freesync to work so that I can connect multiple HDMI sources.
Reactions: thepaleobiker
Headfoot
4,444
641
TBH the easiest method would be to buy one, try it, and return if it doesnt work. Please post back here too to add to the great internet hivemind of info :)
thepaleobiker
149
45
61
Gotcha, I realize your question is more complex than what I had in mind initially - Thanks for clarifying this ! :)
Regards,
Vishnu
