WILL FN45 mobo fit in SK41G case?
Shagg
55
The mobo on my SK41G is dead. Its very difficult to find any FX41 mobos out there and was wondering if the FN45 mobo will fit in the SK41G case. The dimensions on both the SK41G and SN45G are identical except for the back plate.
Anyone know?
Thanks
SHagg
Rigomortis
406
Woops I just noticed you said SK41
Yes I think the only thing that is really different is that there are few connectors on the back and the optical in / out is on the back of the SN45G case.
I was looking at doing the same thing swapping a FN45 board into my case to OC my barton and moving the FN41 to another case.
