L LukFilm Diamond Member Oct 11, 1999 6,128 1 0 Oct 26, 2002 #1 LMK, I need to buy a motherboard for my cousin, but I'm not sure if it will work. Thanks.
A aswedc Diamond Member Oct 25, 2000 3,543 0 76 Oct 26, 2002 #2 It depends on the motherboard, but in the majority of cases yes
B Budman Lifer Oct 9, 1999 10,980 0 0 Oct 26, 2002 #4 The easiest way to tell it to look up a bios on the Asus site to see if it adds cpu support for Celerons.
L LukFilm Diamond Member Oct 11, 1999 6,128 1 0 Oct 26, 2002 #5 It says "Support Intel Mendocino CPU". That's Celeron, correct?
B Budman Lifer Oct 9, 1999 10,980 0 0 Oct 26, 2002 #6 Originally posted by: LukFilm It says "Support Intel Mendocino CPU". That's Celeron, correct? Click to expand... Yes Sir.
P peang Senior member Apr 6, 2000 269 0 0 Oct 27, 2002 #8 I'm using my 440 LX motherboard with slocket + celeron 400 and it run fine.
T thomsbrain Lifer Dec 4, 2001 18,148 1 0 Oct 27, 2002 #9 it'll run but there won't be any overclocking.
S Slogun Platinum Member Jul 4, 2001 2,587 0 0 Oct 27, 2002 #10 My wife is using my old PII, 233 mhz comp that has an intel 440 LX motherboard with slocket + celeron 500. The thing is going fine.
G GregMal Golden Member Oct 14, 1999 1,427 0 71 Oct 27, 2002 #11 Bought a Tekram LX MB a year ago (new) for $25. Used an ASUS slotket with a celeron 500. Everything works fine.......Greg
