Will Emachines XP home cd key work....
Booshanky
The title should be pretty explanitory.
My girlfriend has an emachines PC with xp home on it, but it's completely messed up and I told her I'd just reinstall her OS for her. Only problem is she cant find her recovery CD.
I've got a copy of XP home I can get from a friend, and her cd key is legit. Will that CD key work with a regular retail version of XP home or will I have all kinds of trouble when I do the install?
Thanks.
No. The OS on the rig will be an OEM version while the one on the other PC would be a retail one. Unless you have the same versions, don't try it.
It will cause CD key/serial no. issues and later on activation issues if you go along with it. Best search for the OEM recovery disc.
It should work fine though any optimizations by eMachines for that particular OS won't be installed/applied if there are any.
If by "optimaztions" you mean on-desktop advertisements for a variety of other products and services and various pre-installed, bloated, mostly useless software, then you are correct. 😛
The OEMs call it optimizations so I used that word. I would much prefer bloatware.
I would think a retail oem copy (i.e. oem but not Dell, e-Machines, HP, etc.) will reject the e-machines key. But there's only one way to find out.
On the other hand, if you can ghost a copy to another hard drive, you can start playing around cleaning up the machine. Clean up the spyware & trojans, then running a repair install from the XP cd you currently have. Should work out great. And if not, you've got the ghost image to put back in. No harm, no foul.
Alternatively, download a copy from a file sharing service. This would be legal in most European countries, and I guess in USA as well.
