Will DVI and HDMI Work Together in Eyefinity?
Dashkatt
I'm Setting up 3 monitors for Eyefinity using two Sapphire 7850's in Crossfire. The 7850 has only one DVI connection, (on each card). There is one HDMI and 2 mini-display port connections.
My connection used the one DVI, plus the mini-display port and the HDMI. Well, the first two monitors started right up and work perfectly. The third monitor, (on HDMI), is not getting a signal, (Monitor light stays yellow, no signal).
Eyefinity recognizes that 3 monitors are hooked up, but that 3rd monitor does not display.
Can the HDMI and DVI work together with the 7850? If so, what might I be doing wrong? The monitor works perfectly in all other tasks.
thanks for any help.
