Will connecting my cell phone to a UHF antenna on my roof help?
Sandor
707
If I hook up my cell phone (via some adapter) to the cable that runs to the UHF antenna on top of my apartment, will that help recpetion? I guess the real question is if the UHF antenna can receive any signal that is usable by the cell phone. I got the idea looking at the external antennas for cars- they are basically a cable connecting a phone to an outside antenna.
Colt45
19,720
well considring that cellphones are in the UHF range.. it should work.
if not, at least it will look stupid.
Sandor
707
Not so concerned with looks- I just want to be able to use mt cell phone inside. My signal strength varies between 1-3 bars, and often drops calls. If there is another way, I'm all for that. But the cable leading to the UHF antenna is already there- I just need an adapter.
bmacd
10,869
every kmart i've been to is a dead zone for cell phones, but the second you walk out of the parking lots, you get near full service. It must be something in the building structure....
-=bmacd=-
no0b
3,804
maybe the k-mart people designed it that way?
would make some sense.
Colt45
19,720
Originally posted by: The_good_guy
cell phones are microwave not UHF if I am right.
"microwave" is in the UHF range.
microwave just means short wavelength.
shorter wavelength = higher freq.
anyways, i think UHF is 300mhz - 3ghz ?? something like that.
think most cellphones are in the 2.xxghz range (but dont quote me on it. i dont know much about cellphones.)
JW310
1,582
Not sure about GSM, but CDMA uses frequencies around 800MHz and 1.9Ghz (not both at the same time though).
JW
Colt45
19,720
well i kinda lied.
UHF and microwave overlap..
so some microwave is out of the UHF range, but ive never heard of a cellphone in the over 3ghz range.
