Will computer parts from US work in Australia?
aspire123
[FONT=Verdana, Arial][FONT=Verdana, Arial]I plan to buy computer parts from US (Newegg&Tigerdirect), will they work in Australia?. Will the computer work if I use a power supply made in Australia?
[/FONT]
[/FONT]Motherboard: ASRock 970DE3/U3S3 AM3
CPU: AMD Phenom II X4 965 BE
GPU: HIS IceQ X Radeon 6870
Ram: [FONT=arial, sans-serif]G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 [/FONT]
PSU: LEPA B550-SA 550W 80+ bronze (Is this enough or is it too much?)
[FONT=arial, sans-serif]Case: NZXT GAMMA Classic Series GAMA-001BK[/FONT]
Hdd: Seagate Barracuda 500GB 7200 RPM 16MB Cache SATA 6.0Gb
CD/DVd: ASUS 24X DVD Burner
Will the computer work in Australia?
bryanl
1,157
8
aaksheytalwar said:
You will need to check the psu cable 110va or 220va. Rest should be fine
I'm not sure what you mean. Any cable sold locally will do the trick.
So any power cable bought locally in Melbourne, California, USA will work in Melbourne, Victoria, Australia?
13,834
I would imagine that parts in Australia use the same DC voltages as the parts in the US, so as long as the power supply can accept the AC voltage all is good. Just make sure you switch it to 240.
Also the power supply needs to be installed upside down. (just kidding)
rickon66
1,824
16
And when you short out your cpu and mobo, the build goes down the toilet counter clockwise. Just joking!
Arcanedeath
2,822
As long as you PSU works on 240V and you have the correct cable to plug into the wall or an adaptor it should work fine.
gevorg
5,070
the only difference is that the PSU fan will be spinning in the counter clockwise direction in Australia
