Will BIOS chip from K7Pro 110 clock work in K7Pro 64 clock?
Bekker
1,330
I have a very sweet 950 MHz Athlon slot a that I want to overclock a little to see if I can reach the 1 gig level. When I bought my K7 Pro I was told it had the 110 clock generator, but it has the 64 clock instead. Since the boards are supposedly the same except for the two versions 110 clock and 64 clock, is it possible to change the BIOS chip from the 64 generator to another one from a 110 clock generator? Appreciate any advice and thanks in advance.
Technonut
4,041
It is not a BIOS issue, but the ICS chip. Changing the BIOS chip would not change it from a -64 to a -110.
Bekker
1,330
Thanks! Guess it will be harder than I thought. Maybe I will just let it run at 950.
