I am buying a new amd system with the fx-53
and a socket 939 mobo: http://www.newegg.com/app/viewproductdesc.asp?description=13-127-181&DEPA=1
and I was told the memory was great by somebody on this board as well as several others.. here is thebalistix recommendeded and purchased by me
http://www.crucial.com/ballistix/store/PartSpecs.asp?imodule=BL6464Z505&cat=
it seems to fit my mobos requirements perfectly and work very well on 64 bits but my friend who has worked for verizon and emachines says it isint the best memory and I choose wrong... will this memory scream on my fx-53 on a socket 939.. (the one I posted a link too) will it even run well on an fx-53 at all
here is the memory specifications for that motherboard
CPU Integrated Dual Channel Memory Controller
- Four 184-pin DIMM sockets (Un-buffered Non-ECC DIMM)
- Supports Dual Channel DDR 400/333/266 (Max. 4GB)
thx in advance for any advice,
I actually already have the stuff shipped to my house (its all still in its boxes im on vacation) so hopefully I wont have to make any returns
alb
alb
