- Jun 24, 2001
- 24,195
- 857
- 126
I have two 78000GT cards that I need to power in SLi. My PC Power and Cooling Turbo-Cool 510 doesn't have 24-pin ATX, 8-pin +12v (AUX), PEG connectors, or dual PEG connectors for that matter... heck, I don't even think it has SATA. It was perfect for my last SLi system because it used standard Molex/AMP 4-pin instead of 24-pin ATX, standard 4-pin +12v instead of 8-pin, and both XFX 7800GT video cards each used a single standard 4-pin Molex/AMP connector instead of TWO or a PEG connector. It had just enough cables to dedicate one chain to each card and still have what I needed for the drives and the motherboard's 24-pin alternative connector.
Even though it was perfect for my last dual-core SLI system, it has to be retired for the new quad-core system... but this is a problem. These days, PSUs sacrifice Molex/AMP connector chains for at least two chains of SATA connectors and even more for PEG and dual PEG (Crossfire/SLi). So, both the motherboard and the PSU I'm using now have 8-pin +12v and 24pin ATX, but I am still using the same Molex/AMP-powered 7800GT video cards until the 8800GTS 640MB cards come under $300. Unfortunately, I can't find a PSU with more than two chains of AMP/Molex adapters despite knowing that my cards specifically need the entire chain dedicated to itself, especially seeing as how a normal 7800GT needs PEG connectors.
Now, I have a higher-wattage SLi certified Antec NeoPower to hold me off for now (and a 600w OCZ ready to go in when I get the 8800GTS cards). I considered getting PEG converters that convert them to 4-pin Molex/AMP but, considering that an adapter going the "other way" uses two AMP/Molex adapters from (likely) different 12v rails, I'd kinda expect to get the same out of it. All I can find are 1-to-1 reverse adapters. I will simply use these if I must, but I noticed that the PEG cables plug into the same connectors on the PSU as the AMP/Molex connectors. Are the rails split across connectors in a modular Antec PSU or would a Molex/AMP modular cable connect to a different set of pins inside? If a rail is set aside to pins that only the PEG connectors use, I still want to use those when converting considering that these will be used to power graphics cards. The adapters only provide 12v while a normal Molex/AMP provides 5v too. Might these video cards also tap the 5v rail for a little extra juice considering that they are using one Molex/AMP in lieu of two or a single PEG connector? If so, adapting a PEG connector to Molex/AMP for these sounds like a bad idea.
I guess I can always adapt some SATA connectors, but it different sockets on an Antec PSU provide 12v from different rails, that would be the simplest solution (buying more Molex/AMP modular cables).
