Will an Enermax Noisetaker 420 24pin ATX powersupply work with the Epox 9NPA+
bozack
7,913
12
Product Specifications:
Case Material
Chrome
Case Color
Blue
Compatible Motherboard Type
ATX
ATX Compliance
ATX version 2.03; ATX 12V version 2.0
Power Provided
420 Watts
Number of Connectors
10 Output Connectors (6 Molex 4-pin Connectors; 2 Floppy 4-pin Connectors, 2 Serial ATA Connectors)
Power Connectors
ATX 20-pin/24-pin Female Motherboard Connector; Extended ATX 12V 4-pin Female Motherboard Connector
Additional Connectors
3-pin Fan Connector, Molex 4-pin Video Card Power Connector, PCI Express 6-pin Graphics Card Connector
Power Supply Cooling Fans
Single 92mm Dual Ball Bearing Fan, Single 80mm Dual Ball Bearing Fan
Wiring Type
Copper-shielding Cable
Input Voltage
115VAC/230VAC
Input Frequency Range
47Hz to 63Hz
Input Current
6.7A for 115VAC / 3.0A for 230VAC
Output
+3.3V@30A; +5V@30A; +12V1@18A; +12V2@14A; -12V@0.8A; +5VSB@2.5A
Protection Features
Short Circuit Protection, Over Voltage Protection, Over Temperature Protection, Over Power Protection
Safety Standards
UL (Level 3), cUL (Level 3), VDE, CB, NEMKO, SEMKO, DEMKO, FIMKO
Other components in system are as follows:
2 Cd rom drives
2 IDE hard drives
1 SATA hard drive
2 gb of memory (4x512)
6800 GT Video card
3000 A64 chip
someone said the level on the +12 would be cutting it close??
Thoughts appreciated.
SPQQKY
831
You should be fine with that. It's not the 12v rail I would be concerned with, just the total wattage considering 3 HDDs, 2 opticals and 2 Gigs of RAM and the power hungry 6800GT. You will probably still be good to go.
bozack
7,913
12
Well it may be only two hard drives and one optical, haven't decided yet...
Thanks
