Will AMD K6-2 400 MHz work on Gigabyte GA-586VX mobo?
gnawrot
1,211
Hello,
I wanted to upgrade my daughters system. It is Gigabyte GA-586VX mobo with Intel VX chipset. I flashed BIOS to 2.7 I believe. System is able to recognize dual voltage Cyrix MII 300 at 200 MHz and Pentium MMX at 200 MHz. I wonder if I will succeed if I upgrade processor to AMD K6-2 400 Mhz running at 400 Mhz using 2x multiplier (CPU should be CXT core). Will AMD K6-2 450 or AMD K6-2 500 do the same trick with 2x multiplier as AMD K6-2 400 Mhz. Please let me know. I know that it is not current but this is how things turned out.
I got IOpener from my friend and I wonder if anybody knows how to upgrade CPU from Winchip to Pentium MMX 200 Mhz. It is kind of hard to find info. I found one about AMD K6-2 modifications (requires soldering which I don't mind).
Thanks in advance
Vic
50,422
14,337
Hey, 430VX... memories of the old skool :)
Answer: unlikely. According to Gigabyte, the max speed for that board is 200MHz. The board supports a max FSB of 66MHz and a max multiplier of 3 = 200.
Soldering? I don't know... hardly seems worth it for that rig unless you enjoy that kind of thing. My work just up and gave me a complete P166/437VX rig the other day to part out, and the only real thing of value in it to me is the 4GB HDD.
Vette73
21,503
9
Yea I agree, the VX chipset was older for the socket 5/7 days. Now if it was a 430TX then yes, BUT even then it would have to run the CPU at 66Mhz FSB.
Best bet is to get a cheap Athlon XP and a all in one board like a nForce2 or KM266, fast and cheap
gnawrot
1,211
I already have XP2000+ and don't need another system like it. Maybe I would consider faster system but XP3000+ is not considerable jump for me to bother with it. This system with AMD K6-2 is for my kids (they are still little). If they are going to be teenagers, than obviously I will get something better for them.
KF
1,371
AMDzone BBS K6
That forum used to be the best place for info on this sort of thing.
From memory:
All the later K6s had a 6x multiplier when the 2x was chosen. Obviously that will be 6x 66 =400Mhz even you drop in a 450 or 500.
But these mobos may have bus frequencies of 75 or 83 besides 66. The problem will be that the K6s are rated for a lower voltage than the Pentium MMX.
The Winchip was a drop in replacement for Pentium MMX using the same voltages, although some of the multpliers were different. Changing to a Pentium MMX should not require any mobo alterations.Winchip data sheets Winchip was designed by Centaur which was owned by IDT and is now owned by VIA.
JC
5,836
64
1) all K6-2s 400 or faster have the 2x=6x multiplier remap.
2) You can run the K6-2, but it will prolly run at 2.8v (use a big HSF, won't last forever)
3) can't help you with the IOpener :eek:
JC
