Will AM2 cpus cost more than 939's?
Chris2wire
419
Same cpus, will they cost more on AM2?
And if someone were to upgrade to AM2 should they grab their DDR2 now due to prices?
Unkno
1,659
Common sense tells one that AM2 would cost more than 939s because it's newer.
EffeX
309
Yeah I really want AM2..... I can get my DDR2 300$ ram that does 30-30-30-50 timings!
[/sarcasm]
I think ill stick with my OCZ plats at 2-2-2-5 thanks
GrammatonJP
1,245
Yes, there was a price list out a few weeks ago.. avg cpu is about 9-15 more than the 939 counterparts
F1shF4t
1,583
I might as well skip AM2, my comp is good enough now, and only the very high priced cpus will be anywhere close to being quicker.
I would think that DDR2 would come down in price, but initially it could be the opposite as demands will MAYBE be higher than supply.
Steaksauce
255
http://www.aoaforums.com/forum/amd-moth...65-amd-socket-am2-prices-revealed.html
You sure about that?
Athlon 64 FX-62 AM2 $1,236
Athlon 64 X2 5000+ AM2 $696
Athlon 64 X2 4800+ AM2 $645
Athlon 64 X2 4600+ AM2 $558
Athlon 64 X2 4400+ AM2 $469
Athlon 64 X2 4200+ AM2 $365
Athlon 64 X2 4000+ AM2 $328
Athlon 64 X2 3800+ AM2 $303
Athlon 64 3800+ AM2 $290
Athlon 64 3500+ AM2 $208
Sempron 3600+ AM2 $123
Sempron 3500+ AM2 $109
Sempron 3400+ AM2 $97
Sempron 3000+ AM2 $77
Sempron 2800+ AM2 $67
DrMrLordX
22,970
13,065
Chances are that AMD will try to keep retail prices of s939 high so that AM2 parts will move more steadily. At the retail level, it'll have a lot to do with supply/demand as well. If people are dissatisfied with AM2's performance, don't expect s939 to drop in price until Conroe comes out.
greenmaji
174
[/sarcasm]
We might be better off if we look into how DDR2 works.. double the FSB and double the cas#'s and you have roughly the same speed ram for DDR2 as your DDR..
OCZ (677?) plats case 4 DDR2 would be roughly the same sticks.
sooooooo.. were is this comming from???
And AMD is selling AM2 for a little less then s939 acording to current news, wich has been pointed out already.
Bateluer
27,730
8
AMD needs to move to DDR2 to stay competitive. Intel has already moved their entire lineup over to DDR2, and a lot of manufacturing capability has been changed over to DDR2, leaving less and less for DDR1. Prices on DDR1 will rise, while prices of DDR2 continue to drop.
http://www.newegg.com/Product/Product.asp?Item=N82E16820146565
Thats the DDR2 I'm looking at for my AM2 system, times 2. :p 4-4-4-12 is about the fastest DDR2 module I've seen at those sizes and speeds.
EffeX
309
It was a joke firstly, But as far as gaming is concerned I like lower latency instead of higher megahertz even though DDR=DDR2 in most cases. Sorry if i offended you.
MichaelD
31,528
Freakin' OUCH! :Q $340 for 2GB of ram? Daaaaamn. I'll be sticking with my "old tech" 4400X2/PC3200 rig for quite some time, methinks.
Chris2wire
419
Actually, Im considering buying AM2 with Conroe coming out... This way if Conroe turns out to be not-so-great then Ill already have my new setup. And if Conroe is great, then I simply sell my cpu and mobo and move to Conroe.
But, with the prices of DDR2 as high as they are, I dunno.... 939 and is capabilities are looking mighty sweet... Well, if I keep debating long enough then Conroe will be here anyways.
EffeX
309
I wouldnt buy AM2 im buying a new rig at the end of may and it will most definately be 939. Stick with the tried and true.
