Originally posted by: FoBoT
no, you need cold fusion for that
the extra brick would keep it warm longer after the fire went out, but it can't put out more heat than it burns from the logs
Originally posted by: jsbush
Is there a way I can get it to speed up the combustion by making the air holes bigger?
Originally posted by: jagec
Add some twists to the metal chimney to increase the residence time, therefore heat transfer, of the smoke.
Also will add to the creosote buildup.
