Will a Voodoo 5 fit?
apacide
11
I have a Dell Dimension L667r with an Intel 810E MB. No AGP slots (GYARRGH). I currently have a Voodoo 3 2000 PCI in there and I want to upgrade to a Voodoo 5 5500 PCI to show my respects towards the recently departed 3DFX (really though, what else do I have to choose from for a PCI card?). The V3 is 6.4 inches long. The V5 is a whopping 9.6 inches long. When I look in the case and add about 3.2 inches using a ruler, it looks like a Voodoo 5 will fit, it will just be very close up against the HD. I guess this is because my Dell has a very tiny case. Does anyone have first hand experience with this computer and/or MB and could help?
EdipisReks
2,722
i have a similar problem with my computer. it looked like a v5 would fit, but there was a bolt sticking out of the hard drive bay that was in the way that i noticed right before i was going to order one. make sure you check for stuff like that before you buy one.
--jacob
