winterlude
I'm about to upgrade one of my systems that currently has a 250w power supply. It's running a 466 cleron and i figure that I'll upgrade it to a 750 PIII, add a 7200rpm harddrive (to replace two smaller ones), replace a defective CD-ROM with a DVD, and add a plextor burner. Also, I'll replace the RAGE pro turbo card with an AIW radeon 8500DV when it comes out and bump up the SDram to 512megs from 224. I plan on building a new system in 12-16 months from now based on clawhammer, so this is just a short-term upgrade.
I haven't had any power problems with my system as it currently is as far as I can tell, but I'm wondering if a UPS will supplement any dips in power or inadequacies of the powersupply should they occur. I don't have a UPS for that system, so I figure I could kill two birds with one stone if the answer is yes. I'll likely get a 300w ps soon anyway, but I'm still curious to know the answer.
Thanks in advance
Winterlude
Thanks in advance
Winterlude
