Will a universal remote be able to contol my Olevia?
slayer202
13,679
119
I have a Olevia HDTV, model 332H. My cable remote can't find a code that works with it. I've tried the ones olevia suggests, none work.
I'm wondering if a universal remote would have the same problem?
Slick5150
8,760
Originally posted by: slayer202
Originally posted by: Slick5150
Any Logitech Harmony remote would control it just fine.
I wish lol.
I was looking at this
http://www.buy.com/prod/philip...loc/111/207542027.html
You could get a refurbished Harmony 6 series remote for that price. I don't mean to harp on it, but they really are the best remotes out there. They'll control ANYthing with an IR port.
Check eBay. You'll find one.
Shawn
32,236
53
As long as it's a learning remote then yes it'll work. You may need your original remote to program each key manually if there is no code.
