H HamHam Senior member Feb 19, 2001 507 0 0 May 5, 2001 #3 It said to check to make sure it fit into ur mobo. also I dont wanna spend $10 bucks to buy another heat/fan that will fit.
H HamHam Senior member Feb 19, 2001 507 0 0 May 5, 2001 #5 Sorry hehe, whats a proc? I am ordering it from Newegg.com
N Nutdotnet Diamond Member Dec 5, 2000 7,721 3 81 May 5, 2001 #7 yeah I was asking what proc you were getting to see if the Volcano is what you should really get.
G gramb0 Member Apr 10, 2001 74 0 0 May 5, 2001 #9 Yes it fits on an A7V133, it's actually pretty small.
S stultus Golden Member Dec 2, 2000 1,774 0 76 May 5, 2001 #10 Everything fits the A7V133! The daughterboard gets the capacitors out of the way.
N nomad147 Member May 5, 2001 91 0 0 May 5, 2001 #11 Hell. It must fit. I'm using one and damn impressed!
