flood Diamond Member Oct 17, 1999 4,213 0 76 May 11, 2002 #1 Will a standard desktop ATX psu fit in a 2U rackmount case?
E elektronic Senior member Jul 18, 2001 533 0 0 May 12, 2002 #2 Probably not, my 4U rackmount takes a standard PSU without much room to spare, but if orriented differently, your 2U might. (Mine is mounted tall side, for more room on the expansion card side of the case.)
L Lord Evermore Diamond Member Oct 10, 1999 9,558 0 76 May 12, 2002 #4 1U is 1.75", 2U is 3.5". ATX power supply on the shorter edge is 3.5". It will fit (and in fact specs for 2U cases say ATX).
L Lord Evermore Diamond Member Oct 10, 1999 9,558 0 76 May 13, 2002 #6 If the case says ATX form factor, and it's 2U, it'll accept a standard ATX power supply.
