Question Will a Ryzen 5 be overkill for Nvidia 1050 TI?
Salil
105
4
I have a super old system with ASUS P5Q Pro Motherboard and Q9650 CPU. I do want to try out some of the new gen games like CyberPunk and Homeworld but usually my staple of XCOM like turn based games. Given that my graphics card is a Nvidia 1050 Ti will upgrading to a Ryzen 5600 be worth it or will the graphics card be a bottleneck? Also my power supply is
PC Power and Cooling S75QB 750 W. Will I have to change my power supply too?
NTMBK
10,522
6,046
It will be a bottleneck, but I think it's still worth doing. You'll get definite improvement over your old system, especially if you turn the graphics settings down, and you can always upgrade the graphics card in the future.
DAPUNISHER
32,412
33,388
Games like Cyberpunk are CPU intensive. The 5600 with a $80-$100 board and $45-$50 16GB kit of 3600MT/s ram makes a great low budget platform capable of playing everything smoothly. 2077 has seen multiple big updates, which will allow the 1050ti to provide a good experience using FSR.
Definitely worth the upgrade. If you are in the U.S. Amazon has the best price currently. Black Friday & Cyber Monday are almost here, so hopefully we see it going for under $120 again including the Uncharted games bundle.
19,217
You would see a massive improvement in games that were limited by your CPU. CP2077 should run ok with lowered graphics settings. I don't think you need to change your PSU.
1080 Ti for $250 here: https://forums.anandtech.com/threads/misc-cpu-motherboard-video-cards-fs.2607772/
That should let you balance out your system to an extent.
If you would like to experience raytracing, consider this used card for a bit more dough: https://www.newegg.com/msi-geforce-rtx-3060-rtx-3060-ventus-3x-12g-oc/p/N82E16814137631
maddie
5,203
5,612
The 6600XT = 1080Ti. Just saying.
Salil
105
4
I forgot to add that I aim to connect the system to my bedroom TV which is a LG 65" 65UJ6300 which has a 120 Hz refresh rate, 3840 x 2160 resolution rate.
Reactions: DAPUNISHER
DAPUNISHER
32,412
33,388
With a huge native 4K display, 1080 low with FSR quality isn't going to look amazing in 2077. But it will let you play with over 30fps, which is where I would lock it for the best experience.
Thunder 57
4,275
7,079
The NVIDIA/RT tax is insane. If you want to use RT though that would be the way to go. With the further launch of NVIDIA/AMD GPU's later this year and early next year though you might be kicking yourself if you bought one today. I very much expect prices to be much better in 3-6 months.
Shmee
8,313
3,177
Getting a whole new system build would be wise at this point. The 5600 is a great upgrade, but the 1050Ti is going to be a huge bottleneck, especially for new games like Cyberpunk 2077 at 4k.
DAPUNISHER
32,412
33,388
That's a fact. GTX 1070s and 1660 variants are going really cheap now. That'd be a big performance jump if money is tight.
FSR is keeping old cards from becoming e-waste though. Kryzzp has the 1050ti running 2077 at 1440 low FSR 2.0 performance and getting over 30fps. I think that is how I would play on a native 4K display.
scineram
376
295
Why would that be the case? What is going to happen that would make Ampere cheaper than it currently is?
Thunder 57
4,275
7,079
Hopefully people might wake up and maybe we get a few more articles like this:
RX 6600 for $189(opens in new tab) at 1080p: 0.3593 fps/$ rasterization, 0.1679 fps/$ DXR
RX 6650 XT for $229(opens in new tab) at 1080p: 0.3486 fps/$ rasterization, 0.1701 fps/$ DXR
RX 6700 10GB for $299(opens in new tab) at 1080p: 0.2933 fps/$ rasterization, 0.1492 fps/$ DXR
RX 6600 XT for $279(opens in new tab) at 1080p: 0.2796 fps/$ rasterization, 0.1355 fps/$ DXR
Arc A750 for $274(opens in new tab) at 1080p: 0.2607 fps/$ rasterization, 0.1773 fps/$ DXR
RTX 3060 Ti for $380(opens in new tab) at 1080p: 0.2408 fps/$ rasterization, 0.1773 fps/$ DXR
RTX 3060 12GB for $315(opens in new tab) at 1080p: 0.2282 fps/$ rasterization, 0.1630 fps/$ DXR
RTX 3050 for $267(opens in new tab) at 1080p: 0.1912 fps/$ rasterization, 0.1356 fps/$ DXR
Arc A770 16GB for $349(opens in new tab) at 1080p: 0.2301 fps/$ rasterization, 0.1721 fps/$ DXR
It is criminally stupid to buy a 3050/3060 over an RX 6600. Higher end cards get a bit closer but AMD still wins. Additionally we will see more mainstream AMD and NVIDIA cards in the next few months which should drop prices on the current gen even further.
Of course, if this holds up, I will likely be wrong. NVIDIA will just overprice the hell out of all 4000 series cards and the market will continue to treat AMD GPU's as if they had AIDS.
scineram
376
295
Sure it would be great if more consooomers bought AMD. But it's not happening which is why Ampere is above MSRP after Ada launch.
19,217
I was also wondering whether a RX 6800 + Ryzen 7 5700X would be a better deal for gaming at the same price?
With the RX 6800, you could do some light 4K gaming with some graphical settings lowered in the latest games. Plus, the extra 4 GB VRAM is nice to have for future needs. I personally like the RX 6800.
