Will a replacement Alpha heatsink attachment clip work for an FOP32?
Noriaki
13,640
Got an FOP32 for $5 it just doesn't have a clip, I found an Alpha Heatsink replacement clip will that work?
Mavo
52
I'm not sure about the Alpha clip, but I was using a clip from an older HSF (my FOP32-1 clip was broken). I got my replacement clip early this week. When I put the FOP clip on, my CPU temp. dropped about 8 degrees C. The FOP clip applied much more pressure than the old clip.
You can e-mail GlobalWin (USA) for a new clip.
Noriaki
13,640
Thanks for the tip Mavo!
Don't suppose you have the email you used handy do you?
