Originally posted by: dguy6789
if im gonna spend $400 on a vidoe card, It better do that, do you guys guess the NV35 will be capable of this?
ok thx, I heard that the NV35 will be 256 bit, imagine roughly twice the bandwith the gfFx 5800 ultra has now 🙂
thats like 32GB/s Or think of it this way, a 500 mhz radeon 9700 pro with 1 ghz memory, not exactly the same but, pretty close imo.
I so hope that is true!
Originally posted by: Lonyo
check here
The 9800 PRO gets about 70, 9700PRO and 5800Ultra get 40 (up to 57 for 9700 depending on settings)
I thought someone said the transition to 256bit would mean quite a lot of redesigning, and thus I doubt it'll happen from the NV30 to NV35 since it isn't a major change, its more like 300 to 350. I'm guessing they'll have a 256bit bus with the NV40 though.
Originally posted by: NYHoustonman
You DO realize that the eye can't differentiate between anything above ~60 fps, right?
