- Jan 16, 2007
- 213
- 0
- 76
Will it? Or will they over-clock the same and one would just be paying for the higher multiplier in the Q6700 so one wouldn't have to put as much strain on his/her FSB and RAM?
Originally posted by: myocardia
Nobody knows for sure how high any chip will overclock. But with either of those quads, you're going to be limited by the heat they produce, not by your multiplier. Your chances of the higher overclock are with a Q6600, though, since they can be had in G0 steppings, and the Q6700 isn't yet, at least as far as I know.
Originally posted by: wittangamo
IMHO, you're better off with the lower multiplier. As far as strain on the ram, with the Q6600, running DDR 800 in spec at 1:1 gives you 3.6 ghz at 9x. You've got a much better chance of hitting that than 10x400=4ghz on the Q6700.
Save your money.
Save your money.
You do know you can lower a multiplier right?
Q6600 is 9x, Q6700 is 10x.Originally posted by: nyker96
I think they max out about the same, with a 8x multiplier of q6600, you probably get better performance with a higher FSB at the end.
