Will a P4 800fsb work in a 533fsb motherboard?
chrislong
84
Hi All
Simple question: Any problems running a Pentium 4 800fsb processor in a motherboard built for 533? I assume it will simply run at the lower bus speed, but everything else will be the same. Is this accurate?
Thanks
Confused
14,166
Yes, it should run just the same, just with a lower FSB (and therefore lower CPU speed) :) Also, unless your board supports it, then you won't get the advantage of HT either.
Confused
chrislong
84
man that was fast ;^) Thanks.
So: say a 2.8 (800fsb proc) is in a 533 board...it won't be rated at 2.8 anymore?
Gouv
62
I think the 2.8 has a multiplier of 14 (2800/200) so 14*133 = 1866 on a 533fsb.
