I couldn't find much information on this subject, mostly due to the 460 being pretty new. And I'm no expert when it comes to the technicalities of SLI.
The GTX 460's only have 1 SLI connection, and thus you can only do dual-SLI 460's. But what if you had a 470 or 480 in-between them, with the 460's connecting to the two ports on the 470?
Would this work, or is it unknown at this point?
Thanks.
(If SLI can work in dual with a single strip SLI connector between them, why wouldn't it work like this in a 3-way configuration? I see in tri-SLI setups that it's a double-wide connector going across all three, but why? Or is it so the third card can communicate to the first card past the middle card in a cycle..)
Thanks.
