Will a Geforce 8500 work only with passive cooling?
AnitaPeterson
6,038
593
Hi folks,
In one of the computers I put together from second-hand parts, the fan of the 8500GT video card is about to give up the ghost. It's quite loud and distracting.
It would be too much of a hassle to buy a new fan, so I'm thinking about modding the card to accept passive cooling. I know that there are/were several 8500GT models on the market with passive cooling only, so I hope the GPU will lend itself to this type of heat dissipation.
I had the same problem many years ago with a Geforce 2 GTS, and ended up installing a passive Zalman ZM-NB47J aluminum heatsink ( http://www.newegg.ca/Product/Product...82E16835118214 ) on it.
Do you guys think something like the Zalman would be enough, or should I look into adapting a bigger heatsink? perhaps an old Socket 370 cooler?
The people who will receive this computer are not gamers; they'd be using this as a HTPC.
Jimzz
4,399
190
If no gaming just add a couple case fans and it should be fine. For what a aftermarket heatsink cost you could get a used working card. So try the cheaper case fans first.
AnitaPeterson
6,038
593
I ended up attaching an AthlonXP CPU fan to the cooler - which makes sense, since it's relatively quiet AND powerful... And it makes me chuckle, seeing the AMD logo on a nVidia card...
Blue_Max
4,223
153
I've used plenty of these - provided it's not used at 100% load (Folding, gaming) for very long, it'll be fine with just a good heatsink. I have a passive 7600.
