Will A CPU Upgrade Help My Compaq Presario M2010US?
Harvey
Administrator<br>Elite Member
70
I was paid for some work with a Compaq Presario Model: M2010US. It's in great shape, and I'm sure upping the RAM from 256 MB to 1 GB will help a lot, but I wonder if it would be worth upgrading the CPU from a Celeron M 350 to a Pentium M?
This model may use the same motherboard as <a target=_blank class=ftalternatingbarlinklarge href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00311139&lc=en&cc=us&dlc=en&product=464088
">model M2007US</a> with 1.50 GHz Pentium M Processor 715A, but I'm not sure since this model has a different wireless setup.
So far, I've figured that appropriate Pentium M CPU (Dothan core) upgrades MAY be:
1.50 GHz: 715
1.60 GHz: 725
1.70 GHz: 735
Questions:
1. Am I looking at the right Pentium M models?
2. Will upgrading to a Pentium M improve the performace enough to be worth it, or should I just stick with adding more RAM?
3. Which chip form (socket, etc.) does this machine use?
4. Anything else I should know?
TIA. :beer: :thumbsup: :cool:
DrMrLordX
22,905
12,976
I believe you are looking at the proper CPUs, yes. Upgrading your CPU will help you by giving you more raw clock speed and doubling your L2 cache. It won't be a huge boost, but it might help you out if you get one of the faster models. The greatest weakness of the old Dothan cores (and Banias) was multitasking during day-to-day use, so running a faster Dothan won't really help in that department. I don't think you can run a Yonah chip in that socket, though.
I forget exactly which socket Dothan used, but I believe it was a version of socket 478 or 479 that was not pin-compatible with desktop s478 processors.
Amaroque
2,178
Going from 256 MB to 1GB will have a much greater impact on overall performance, and system responsiveness than a CPU upgrade.
If you are running XP, your system is severally bottlenecked by lack of RAM. Paging active data from RAM to HDD all the time is very sloooow.
996GT2
5,212
Try the RAM upgrade first (in fact, get 2 GB if you can...hot deals section has some nice deals on SO-DIMMs)...I doubt you will feel the need for a CPU upgrade of a few hundred MHz after that.
myocardia
9,291
30
The motherboard has a max of 1GB. Good thinking, though, if it didn't.;)
I agree; nothing seems slower than paging, especially when you're waiting on a 4200 RPM drive.:D
Harvey
70
Thanks, guys. :beer: :thumbsup: :cool:
I agree that a RAM upgrade is the first step, and a both that and a better hard drive are "stock" upgrades that don't go beyond the original specs.
I've learned a little more about the machine. Specifically, it definitely uses the same motherboard as the P4 M based M2007US, except that it doesn't have a couple of sockets for features included on that model, so my list of possible Socket 478 CPU's is right. For now, that's just info I'll save that for a day when I have both the ambition and the spare cash to try it, but RAM and drive are first.
