Will a 9700 pro work with a KT7A-RAID Mobo?
BoomAM
4,546
Hi,
Will a Sapphire or any, 9700PRO video card work with a Abit KT7A-RAID?
As far as i know, it should and the only problem, is having to press reset after a cold boot.
Any other problems that i should be aware of?
Thanks in advance.
BoomAM
4,546
Thanks for the reply/s
Ive read from several sources, and the shop itself, that the latest BIOS, A9 and earlyier, have the problem.
There have been no fixes as of yet from Abit. A can live with that problem, i was just wondering of any other problems that there might be.
I have revison 1.2 if that helps anybody.
Thanks in advance
BoomAM
4,546
AGP slot? whats one of those? Is the thing that i put CD`s in? lol.
Seriously though, are there any known major probs that i should be aware of?
BoomAM
4,546
Got the Sapphire 9700PRO. Its the revision 3.0 one, so no cold boot probs.
Thanks for the help guys.
You can probably find info on my few problems with the card if you search for my recent threads. (under video)
Thanks again.
