I am building a HTPC that will most likely never go beyond the following max config.
Will a 300W PSU power this OK?
1. Epox 8K3A+ Motherboard
2. AMD XP2200+ most likely underclocked to reduce heat
3. Alpha PAL 8045 Heatsink with low speed fan
4. DVD-ROM
5. 2 Hard Drives MAX
6. ATI Radeon 8500LE
7. Sound Card
8. Capture card
The case has only 4 bays max so if I add a floppy this is the MAX config.
I am leaning towards yes since I have no issues with my 380W with a ton more in it now.
In my other system I have a bunch of high power fans, 5 Hard Drives and 2 Optical drives on that 380.
Mark
4. DVD-ROM
7. Sound Card
8. Capture card
Mark
