Will 800 mhz ram work with 1066mhz ram?
Squirrel127
9
Also, does anyone want to buy 1 or 2 sticks of OCZ Platinum 1GB 1066 MHZ 240 Pin DDR2 SDRAM? Each stick works fine, it's just that my MOBO won't read them both at the same time and I want more than 1 gig of ram.
Squirrel127
9
Also wanted to add that only 1 stick has been used for than about 5 minutes, and it's only been in my comp for less than 2 days.
Mr Fox
876
Originally posted by: Squirrel127
anyone?
Did you try what I told you to try in the other thread ???
Until you try that no one will help you... when we offer you assistance... you need to try it otherwise the silence is deafening.......
Good Luck !
Squirrel127
9
Sorry for the no reply, I haven't had much time to use my computer lately, I did try overclocking the memory to 2.2v, even tried up to 2.5v, and although it did make the MoBo respond to the changes by thinking a little longer on the memory stages of start up, it still wouldn't recognize both sticks of ram.
