hi
just wanted to know if Antec True Control 2 P/S http://www.frozencpu.com/products/3218/...550W_ATX12v_v20_Power_Supply_Unit.html will be enough for the following:
EVGA 768-P2-N831-AR 8800GTX R - vid card
CORSAIR TWIN2X2048-8500C5D R - ram
MB EVGA 122-CK-NF68-TR NF680I 775 - M/B
CPU INTEL|C2D E6700 2.66G 775 4M R - CPU
CPU FAN ZALMAN|CNPS9500 AT RTL
assume i will not be overclocking, well, not much, maybe jsut to run the 1066 memory at actual 1066 if need. may throw in a couple of extra fans for the summer time since i live in a pretty hot climate.
i will also be using a H?D on which i havent decided yet, probobly Seagate, and a DVD RW drive. going to try out the onboard audio and headphones, so no additional sound card unless it sounds horrible or causes some sort of drama.
so opinions on that with the P/S listed, or is tehre a betetr 1, BTW my number 1 priority is noise level. i want it to be as adequate and compatible, but as quiet as possible.
thanks.
thanks.
