I'm not trying to have two inputs into the same set of speakers. I'm trying to find the best (yet cheap) way to connect the RCA audio from my PS2 to my computer speakers. If I used the Logitech game console adapter, I would disconnect the computer speakers from my sound card and connect them to that adapter.
I didn't get a chance to open up the adapter last night, so I think I'm just going to go ahead and order the adapter with 2 RCA female and 1 3.5mm male. Today's the last day for the rebate on the wall mount, and that adapter's only $2.50.
OK, I just thought of one more question. While I'm ordering stuff, I'd like to order an extension cable for using my headphones (HD280Pro) with my receiver (Panasonic XR55). The headphone cord just barely reaches my couch, so it's quite uncomfortable unless I lean forward a lot. I'm wondering what cables or adapters I'll need to do this. My HD280Pro has a 3.5mm plug that screws into a 3.5mm-to-1/4in adapter, and I plug that adapter into the 1/4in jack on my receiver. Will that adapter only work with the HD280Pro, or would I be able to use it with a 3.5mm extension cable? If it doesn't work with the 3.5mm cable, is my best bet to get another 3.5mm-to-1/4in adapter and use the extension cable with that?
I'll be ordering sometime today to get in on that rebate. In case anyone's wondering, I'm getting the Mustang
MVSTAT4 to wall-mount my Pioneer 5080. It's $89 with an $89 mail-in rebate. I'll get free shipping if I spend $99. Fatwallet has 3% CB right now, so I should wind up getting the mount plus some cables and adapters for about $7-10 after CB and MIR.
