Will 16 gauge monster cable fit in the logitech z560?
AnandtechUser
100
lmk thanks i want to get some to improve sound also i am thinking of hooking a center speaker to the rca on the back of my gtxp and have a 5.1 cheap way haha
WheelsCSM
161
I'm using 18 ga Radio Shack wire in mine, and there is a little more room, so I would guess that 16ga would work. You could always use bannana plugs at the speakers, and they sell some things at Best Buy (saw them yesterday) that screw onto the ends of cables and adapt down to a smaller gold wire that would go into the sub ($$$). Personally, I would say that 16ga Monster Cable is overkill unless your speakers are really far apart. For what it's worth, I could not tell a difference in sound quality when I changed the cable, I just needed longer wires.
amdskip
22,530
13
I wouldn't waste your money on monster cable. 18 gauge Radio Shack cable is gonna be the best thing you can use.
eaadams
345
If you have the cash for 16 gauge monster wire then save it and go 5.1 the non cheap way. Ask HT people and they will usually tell you monster is nothing special and most anyone will tell you the place where people spend the most and get the least improvement is via speaker wire.
dm33186
111
ive got 16 ga monster on mine and it doesnt fit into that tiny little hole so i wrapped it around the post seems to be working just fine
