Wii remote only connecting when using other remote to connect it
FuryofFive
1,544
9
im having an issue with one of my remotes. it wont turn on the system, it wont connect or nothing unless i connect it with the other remote through the reconnect screen.
i bought this one new at walmart.
question is.. is this a known issue. or am i SOL heh. i mean like i said it works.but id prefer to use it as my main one, so i can keep my other one in my mario kart wheel.
FuryofFive
1,544
9
my first one works fine... the 2nd one works only when synced with the remote that came with the system..
Baked
36,052
17
the wiimotes sync w/ the wii console, they don't sync w/ each other. did you or did you not read the wii manual to sync the wiimotes? when sync properly, you shouldn't encounter the problems you described.
