Wii remote chargers
Pandamonium
1,628
Does anyone own a Wii remote charger that can charge 4 wiimotes with the OEM sleeves on them? The closest I've found is the Psyclone inductive charger, but it looks like it might not play well with the sleeves. If you've got first or second hand experience, please chime in!
Spoooon
11,563
203
Originally posted by: sonambulo
Easily the best model on the market...but pricey and does not work with WM+
Just get a regular eneloop charger and some batteries. Save yourself the cash.
I prefer this to using any kind of charging station. That way I can put the controllers away, not have something plugged in all the time, and can replace batteries as they go bad.
The motion plus sleeve is easy enough to take off and put back on that occasionally having to mess with batteries is no big deal.
Crow550
2,381
Monoprice.com has some Wii chargers: http://www.monoprice.com/produ...p?c_id=108&cp_id=10830
Here just a list of chargers: http://www.monoprice.com/produ...word=wii+charg&x=0&y=0
Otherwise I'd say go with a 1 hour or 30 minute which usually changes 2 at 30 minutes and 4 at an hour and your good to go. Yeah make sure it's NiMH.
I have a 30 minute Digital Concepts changer. Been using there batteries for quite some time. There cheap and work great. Been using them for a couple of years. No issues. They last long. Use em in a digital camera, wiimotes........Work fine.
This is what I use: http://www.sakar.com/p-776.aspx?categoryid=138
