Could be pretty much anything causing that, from your wifi adapter drivers, windows issue, router issue, or radio spectrum interference in your local area.
Note also, that for certain file-servers on the internet, they intentionally serve up files in "bursts" like that. It may not even indicate that something is necessarily wrong.
