- May 23, 2002
- 16,928
- 8
- 81
So I'm looking for some information on how to get the furthest range on my wireless router that I can. I think I read that N routers have a greater range but I'm only using G cards. If I get an N router, does the range boost only apply when using the N signal or would the extra range work for G cards as well?
Or is it really not that significant? I have a couple G routers I can make use of but would have to buy an N router if I'd get a decent addition to the range.
Thanks.
Thanks.
