Wifi quality downgrade after connecting external HD to EA6300
pw257008
288
I connected a 1TB Toshiba Canvio external to my Linksys EA6300 router yesterday, and I've been having wifi issues since. Ookla speedtest usually gives me 15 down/1 up, but just now, I got .35 down/.36 up. Anyone have experience with this or know anything about the issue? I've rebooted the router a few times, and I haven't touched the firmware.
VirtualLarry
56,587
10,225
USB 3.0 interferes with wifi something bad. Can you force USB 2.0 mode somewhere in the menus? One idea might be to get a powered USB 2.0 hub to put between the router and the external HDD, forcing it to use USB 2.0 mode.
azazel1024
901
Correct. A few manufacturers have shielded ports, which can help. Most with USB3 ports have an option in the admin page to downgrade the USB3 port to USB2.
Not sure why router manufacturers ship routers with USB3 ports at all. At the very least shield them!
This can also be an issue connecting a USB3 device to a laptop, but generally the Wifi antennas are far enough from the location of the actual ports (9 times out of 10, they are in the display section) that the interferance is minimal and/or unnoticable. Not so much when your port is probably located a couple of inches from your antennas.
It can cause whicked bad problems when using something like a Wifi USB adapter or Bluetooth USB adapter when right next to a port using a USB3 device.
You'd think it would be one of the things the USB Alliance realized when designing the USB3 specification (IE they are transmitting in roughly the 2.4GHz band over the wire!!!).
Something I pray is fixed with USB3.1, that they move to something away from Wifi, like 4GHz or something.
pw257008
288
very interesting, thanks for the info guys! very weird, since i'd thought one of the big advantages to usb 3 is facilitating faster transfer speeds over a network when using a usb3 equipped router, but i guess that's only really true if you hard wire everything and ignore the wifi. it does seem awful absurd. i'll give the hub a try or play around with the settings sometime when no one else needs the network.
