WiFi ICS complex problem
rdskl
I have a small Home network using a WiFi router and am having problems sharing internet through PC2 to my XBOX.
Here is my Network toplogy:
visual:
http://www.geocities.com/rdskl/SETUP-3.jpg
Description:
PC 1 (1 Nic):
Connected to the internet via router using DHCP, given IP by router 192.168.0.100
Default gateway : 192.168.0.1
Subnet: 255.255.255.0
PC 2 (2 Nic):
Nic 1 : Connected to the internet via router using DHCP, given IP by router 192.168.0.101
Nic 2 : Connected to XBOX via crossover cable, CAN FTP files. Static IP: 192.168.1.112
Default gateway: 192.168.1.1
XBOX (1 nic):
Connected to PC2's NIC2 via crossover cable. FTP works. Static IP:192.168.1.111
Default Gateway: 192.168.1.112
Now when I try to enable ICS on NIC1 on PC2 I get the error that 192.168.0.1 is needed to enable sharing. But I cannot change PC1's default gateway IP(its already set to DHCP).
I need to enable ICS on PC2 so the XBOX can access the net.
Pls help.
Thank you
