Franco_Barba
Hello everybody, I'm new here and this is my first post.
I'v been searching to find an answer but I could not find anything that matches what I want to do.
I want to have a extremely huge WiFi coverage, stability and speed.
I have a 180m2 (1900 Square Ft) house with a large back yard and a front back yard.
Right now I have the Asus RT-AC66U
(http://www.asus.com/Networks/Wireless_Routers/RTAC66U/
Which is working really good, I have good signal and speed link in almost all the house, all the back and front yard. The house has two levels and the router is on the main level in the office by the left side of the house.
So the problem is that far in the back yard the signal is a little weak, and in the kitchen there is low signal close to the sink which is surrounded by walls and kitchen electronics, its a U shape kitchen. upstairs the signal is good but it is not at its maximum. And the most important thing is that I want my wifi to reach some distance outside my house, right now I can drive about 40 meters down the street and I have poor signal and slow speeds, but I get signal, depends on which direction I drive.
So what I want to do is to replace the 3 antennas on the RT-AC66U with 3 powerful antennas relocated with cables.
One on each side of the house and on up in the roof of the house elevated with some kind of small tower.
My idea is to have wifi for example in the coffee 4 blocks away, or when I'm coming home catch the wifi a couple of blocks before I get home, and have perfect maximum signal in every single spot of the house
I'v been reading that the usage of long cables to relocate the antennas generate a huge loss of signal, so I was wondering if there isn't another type of cable or quality that doesn't loss signal, Some blinded cable or fiber optic, does that exist for antennas? or use amplifiers in the middle. Like the fiber optic wires crossing the oceans to connect all the continents.
And what antennas should I use for achieve what I want, especially for the roof.
I don't really want to use multiple devices or any kind of wired connection, I'm desired to do everything 100% wireless no matter how much it can cost.
I want to use the 5.0Ghz with the 802.11AC wifi, as soon as ac adapters and ac devices become available I will switch everything. But as I have iPads and iPhones I need to keep the 802.11N too
I would appreciate any ideas!
